I have a Little Wonder leaf blower with a 5HP Briggs model135212. It will start and run for about 45 minutes to an hour then dies and won't start. Let it set overnight and it starts right up but does the same thing. I took it to a local repair shop and they repaired it. Said they "tightened the head bolts, cleaned and adjusted the carb, and replaced air filter and said it was OK". I was very skeptical and ran it when I got home. Started right up and ran for 45 minutes and died and would not start. Waited about a 1/2 hour and started it up. It ran for 15 minutes. To me it sounds like an electrical problem. I am taking it back tomorrow and would like some expert advice.
Thank You
Thank You
