Are you the same AVB on the OPEforum.com forum??The hex is just another place the filter can leak. Or at least that what on my last oil filter change on my Chevy S1500. Put on new Purolator filter and with a couple weeks I started losing oil. It looked a rear main seal failure until I ran UV oil dye test. Two stress cracks right where the hex were formed. But considering that filter cups are made single flat sheet stretched into a cup I surprised that I don't see more failures. It the same process that they use to make soft drink and beer cans,
Initial non leak was just that the paint hadn't failed. Purolator wouldn't honor their filter warranty either.
As for the 49065-7007 I just the Briggs 492932S or aftermarket version.
