drforsythe
- Aug 8, 2020
- 1
I have a JD Z225 zero turn with 42” deck. Problem I’m having getting bad cuts seems very uneven. In checking my deck I’m not sure I’m seeing things correctly.
Flip deck over to check every thing im seeing what seems to be blade height issues. If I put the blades to center of deck and measure end of blade tips to deck one measures 3 1/4 inches the othe blade measures 4 inches. Spindles are not loose or bent Blades aren’t bent, new blades. Is this normal or what That’s why I joined this forum I’m stumped.
Anybody got an answer
Thanks
Donnie
Wake Forest NC
Thanks
Donnie
Wake Forest NC
