lawn mower fanatic
- Jun 8, 2012
- 321
- 6,749
Coming in 2013.....
The Exmark Commercial 30 walk-behind. :licking:(Exmarkç—´ New Commercial Walk Behind - TractorByNet.com)
From http://www.exmark.com/pressroom/:
"News Releases:
For Immediate Release
Increase productivity, profitability with New Exmark?ï½® Commercial 30 Walk-Behind
43-percent wider cut per pass than 21-inch mowers cover more ground in less time
Maneuverability and balance similar to a Commercial 21-inch model
3-in-1 cutting deck quickly changes from side-discharge, mulching or bagging without tools
High-performance blades and deck design deliver superior cut quality contractors expect from Exmark
Louisville, KY (October 24, 2012) With the introduction of its Commercial 30 walk-behind at the 2012 GIE+EXPO trade show, Exmark?ョ gives landscape professionals a new option that can significantly improve productivity compared to the typical 21-inch commercial walk-behind mowers they豎*e using today. With a 30-inch cut width, the new model offers 43-percent more cut area per pass, yet maneuverability and balance remain similar to a 21-inch model.
The Commercial 30 delivers enhanced productivity with the superior quality of cut thanks to its timed, two-blade, 4.6-inch deep 3-in-1 cutting deck. The deck design allows users to change from side discharge, to bagging or mulching, quickly and easily without tools, and it works in conjunction with the timed blade system and the design of the blades to provide optimal cut quality and reduced horsepower consumption in all three cutting modes.
*ï½¹ur customers are excited about the Commercial 30 because it does many of the things they閾エe been wanting in a small walk-behind, but havenéž been able to get until now, said Exmark Director of Marketing, Daryn Walters. 逧д逞エ more productive, yet still easy to maneuver in tight spaces. It逞エ compact, so it transports easily on a trailer or in a truck. It逞エ cost-efficient, engineered to be durable and flexible to the conditions at-hand.
蜈クhe Commercial 30 can give contractors much of the productivity of a larger, more expensive walk-behind combined with the maneuverability and cost-effectiveness of a smaller mower.
A standout feature of the reinforced structure, frame and cutting deck on the Commercial 30 is the patented front height adjustment system, designed to withstand years of commercial use without the need for ongoing service or repair. In addition, a single-point rear height adjuster design isolates the transmission and frame from damage due to impact loading, providing superior durability. One-half -inch steel wear bars, a 1-inch diameter bumper and metal side discharge cover are all designed for durability and cutting deck protection. Heavy-duty side braces and engine guard provide superior engine protection and increased frame durability.
The Commercial 30 features a positive drive transmission with infinitely-variable ground speed up to 4.2mph. The positive drive design couples left-and-right side drive wheels for maximum traction and the large, heavy-duty wet clutch transmission is custom-built for Exmark to provide increased service life. The self-tensioning belt drive to the transmission prolongs belt life and effectively eliminates the need for ongoing service adjustments.
The key to the two-blade deck drive system on the Commercial 30 is a simple timing belt system that maintains blade position and isolates the engine from shock load. Blade drivers incorporate a shear pin, which allows for simple service and replacement and also protects the timing system in the event of an impact. An access panel at the front of the mower allows users to easily inspect, clean or make adjustments to the system. Heavy-duty spindle assemblies utilize robust ball bearings, forged spindles and die-cast housings.
An optional high-performance mulch kit is available to provide enhanced mulching performance in especially demanding mulching conditions, such as wet, heavy grass or heavy leaf conditions. The kit can also act as a fill-reduction kit when operating in bagging mode, which reduces the number of times the bag is emptied.
蜈クhis type of setup (running a bagger with a fill-reduction kit) has proven to be very popular with quite a few of our customers, Walters said.
Other features of the Exmark Commercial 30 include:
Kawasaki?ï½® FJ180V engine.
One-gallon remote fuel tank.
2.5 bushel (23 gallon) bag capacity.
Precision sealed ball bearings in high-impact composite Nylon wheels with semi-pneumatic rubber tires. (Front: 9閧コ2.5? Rear/Drive: 10閧コ3?
Safety Package includes Blade Brake Control (BBC) allows the operator to disengage the cutting blade without stopping the engine.
Mower includes bag, mulch plug and side-discharge chute.
Learn more about the new Exmark Commercial 30 walk-behind, or any of the company逞エ 2013 models, at Exmark.com, or call (402) 223-6300.
About Exmark
Exmark Manufacturing was incorporated in May 1982 as an independent manufacturer of professional turf care equipment. Today, it is the leading manufacturer of commercial mowers and equipment for the landscape professional. In additional to designing, building and marketing quality turf care equipment, Exmark逞エ goal is total customer satisfaction. All Exmark products are designed to help customers increase productivity while delivering unmatched quality. Products are sold to distributors and dealers who share the company逞エ commitment to customer service and quality products.
-- 30 --
Note to Editors: All media inquiries, image or interview requests should be directed to Nichole Allen at (402) 223-6348 or nichole.allen@exmark.com. For other inquiries, please contact Exmark Mfg. Co., Inc., P.O. Box 808, Beatrice, NE 68310-0808; (402) 223-6300."
