- Sep 24, 2017
- 284
- 6,844
Trash it.
:laughing::laughing::wink:
Don't tempt me :thumbsup:Trash it.
Yes engine has been stripped down and all the lobes were checked OK .... but thanks for the suggestion :smile:
Neo, can you post a You Tube or some sort of video /audio?
It seems you have the engine bolted to a stand of some sort but even still, I don't hear much of a "pop" but it certainly runs pretty rough.
Between putting the "new carb / manifold" on and it's improvement, does it run any smoother??
If it's not "popping" with the new carb / manifold (the issue is gone), seems you narrowed it down to the intake / carb. Is one plug burning a different color than the other (whitish / lean)?
A lazer / infrared temp gun pointed close to the exhaust manifold/adjacent to the heads would show if one side is hotter than the other (the hot cylinder is working properly, the other isn't).
I forgot if you tried spraying starting fluid /similar around the manifold (while running) and check for a rise in RPM's(indicating an air leak /lean condition).
I'd examine (and do the above test ) to the intake manifold first. Then go thru the carb again.
Re replacement, I'd try and get a used set up or new if possible. The single barrel for testing should work fine. The lower HP is likely FROM the single barrel carb and NOT having a dual carb set up.
You can always put the engine back on the mower with the single barrel carb and run it, see how she runs. I doubt it'd be a problem...
Yes much smoother.
Sorry I neglected to check the plug colors but Cylinder 2 was still running hotter .... Single barrel Carb is back in my John Deere now so can't check this now.
Can you please explain why the hot cylinder is the one that's working properly?
Yes I've tried spraying the plastic manifold a few times now... But it's never shown anything.
So we have one vote for Single Carb and one vote for staying with the Dual Carb :confused2: :laughing:
Has anyone swapped out a plastic twin barrel manifold for an aluminum twin barrel manifold?... are any modifications required?
