Hello all,
I have this 22hp engine that is giving me some intake/carb pop at idle.
I replaced both heads due to a bent push rod on one and valve guide movement on both heads. I have had the carb apart more times than I can count and readjusted the valve lash, trying to nail down the popping. Plugs and fuel pump are new and I tried pulling the coil wire between the two coils to see if that helped.
I have read all sorts of things on the web but figured I would post some video and see if there might be something I missed. Model 406777
Thoughts?
Thanks
Bill
Thoughts?
Thanks
Bill
