YEs
They are there to stop dirt dropping into the hole and grinding it ovalThe amount of air the leaks down the sides of the throttle shaft ( choke does not matter ) is taken into account when the jet sizes are determined.
Check your fuel lines and filters for small cracks. My fuel line had a crack that would take in air, but did not leak gas. Check from the tank to the motor...
