Check needle & seed in carburater dirty or sticky. Could easely happen after stored for long time
PJ
Needle & Seed?..lol
Whoaaa' now PJ, I think you meant Needle & Seat? But oh ya' if not, a seed inside the carb could make for some big problems for any Briggs. Especially if its a great brigg ol' tree seed. Sorry ' I had to say it..
Sorry' PJ I mean no offense but its been on here since 2012 without a peep I see. I had to end it..lol
Good point here and same issue here. So' I finally pulled my carb bowl off and its all clean inside & all is working fine but yet' still same issue! Mostly its a dry filter but starts/runs, it started missing first & noticed it had maybe 1/8th a thimble of fuel inside my filter at the very most while its running so I'm sure its running way too lean! Been through all the options posted here so a weak pump is most likely my issue too. Almost 100hrs (200 on mower 2006) again on 2nd pump so maybe it's pump replacement time anyway? Idk how long these pumps should last honestly. Not long it seems?
Most of our 1.5 acre mowing is still done with my old Wheel Horse since its faster mowing than this one. This Husq is my wife's mower just to mow whenever she wants to work outside. Assumed it had some sediment in its bowl at 200+ hrs but it was simply spotless inside. Since I run only top-tier fuel in all my engines it really does helps clean a fuel system out, there are just no doubts as I've seen it first hand on our vehicles too.
So now what? 1st Pump lasted 130hrs and 2nd pump lasted only 78hrs. Yes pumps are very cheap but does anyone recommend certain pump brand/design options so I can possibly better things? Sure don't last like my Kohler mechanical pump by any means, its 40yrs old & still going strong.. What is best, simply buy another OEM "Again"?, Buy cheapest pump located since they don't last long anyway (look same outside, junk inside idk??), Just change over to electric pump?
What's the best route to go with these without high conversion costs? Unlike today's manufacturers who design products to fail a bit too soon for profits, I'm more about long term reliability/durability of things than anything else so if something can actually be upgraded, sometimes its worth all the hoops & hassles one faces to change it all. Just my honest opinion in most cases, not always, we all know what's happening to our world. Seen some cheap pumps online but I mean just too scary cheap, know what I mean Vern?
Thank you all in advance. Great site too!
Warning-
Watch the summer Heat folks, lost a friend from it a few yrs back it sneaks up extremely fast, so drink lots of fluids the night before & the day of.
A few more ounces may save your arse my friend!
