lsxcubdeere
- Jul 16, 2014
- 22
I put a battery on my 214 and I had to jump it to get it to start. I put a multi meter on it the battery is getting charged it runs 14 volts while running. I also did a continuity test on the ignition switch and it's good. All the safety switches are good. I also replaced the positive battery cable. So am I looking at a bad starter solenoid?
