2011 TROYBILT BRONCO 13WX78KSO11
Scrubcadet10
Moderator
Staff member
That's odd. those engagement systems are pretty simple.......
Fish
Well, I meant that the pictures you take, you should post them on here.
Deck belt routed incorrectly is a good possibility. As the moving idler is pulled to engage the blade brakes by it tension spring it is engaging the belt tension. And when the normal PTO engage position is disengaging the deck belt tension.
KER
I will recheck the belt routing and ensure all the components are in place ie the bracket belt guard( 2 ea # 54) for the idler pulleys (2 ea # 48)
Thank you
KER
TROYBILT 42 IN G TWIN BLADE DECK 13WX78KS011
By chance which of the 3 holes in the L/H #32 and R/H #33 on the deck hanger rods upon reinstallation of the mower deck ?
Scrubcadet10
Moderator
Staff member
I've always put my cub on the lowest one on those hangers/
KER
The deck belt broke and so I will replace and see what happens from there ?
KER
Yes, we're talking about the deck now.,, and to answer your question on the drive pulleys, yes, both are supposed to spin.
let me put on my thinking cap
My Troybilt is 100 % and FMC, I replaced the deck belt, deck engage cable, and made some adjustments on the mower deck within the idler pulley and everything is working.
Thank you for your help and input on this.
