2005 Kohler Command CH22 engine blower housing
VegetiveSteam
There is one down below the voltage regulator and one in the same place on the other side also. You probably will have to use a wrench. I don't believe you'll be able to get a ratchet and socket in there.
bentrim
Plus the ones at top top that thread into the head there are two about half way down the sides if you have an oil cooler there is not one under the cooler but there is one on the other side and there are two at the bottom on each side, usually one grounds the regulator. There are none on the bottom. Of course the screen needs to be removed.
My Hoe
What is the purpose of pulling the blower housing?
To do the annual "mouse nest eviction" that will cook an air cooled engine if not removed?
My Hoe
I didn't bother looking up the model numbers to see if this is a vertical shaft engine or, as has been suggested, a horizontal shaft engine. On my 2005 Khohler V-Twin (I forget the model, but it's something like 24 hp on a Cub Cadet lawn tractor with a 54" belly mower) I seem to remember a bolt near the bottom of the engine, possibly where the oil dipstick tube mounts? Or possibly near the starter motor?
Also, as was mentioned, the SCREEN bolts (up on top of the engine, over the flywheel) may also have to be removed.
As I get older, I can say that wearing a headlight (literally) and reading glasses are becoming requirements in situations like this. Between being able to clearly SEE, and carefully feeling what IS loose and what is not, you should have this knocked.
Also, FINDING A YOUTUBE video of this annual maintenance procedure, for your exact model, should not be difficult--or even a different model with the same engine.
As in cleaning the cooling fins on these air cooled engines.......... Amen to that.
I often blow out the engine with compressed air through the mowing season and it's always worked for me.
Your engine.
Really needs the top shroud removed to clean the fins and all around the block. Read your engine manual.
hlw49
kohler makes a kit you can buy that has the templates to cut your blower housing with metal covers so you can just take the cover off and you don't have to take the blower housing off.
My Hoe
Wow--no kidding? Would you happen to have a link to these kits?
Anyone with real world experience with using this "cut out" kit?
Auto Doc's
Sorry hlw49, that has been a misleading story/rumor passed around for years.
I was at the local John Deere dealer in my area around the time these kits came out. They were a Kohler v-twin fan shroud inspection cover kit.
They are inspection covers meant to only check for debris. To actually clean the cylinders and heads cooling fins effectively, the fan shroud and tin covers still have to be removed for a thorough cleaning. The inspection covers are not a "short cut".
We still had a rash of overheated V-twin Kohler engines even with these so-called "cleanout kits".
Another issue hiding under there on these engines is the crankcase breather which has a tendency to seep oil past the gasket, then dust attracts to the oil and builds up. The older they are, the worse the buildup becomes.
My Hoe
@Auto Doc's: Even if they inspection port kits could not be used as cleanouts, I would LOVE to have such a kit on my Cub Cadet, so that I could inspect for mouse nests w/o having to take the engine cowl off.
Do you know if these "inspection cutout kits" are still available?
Do they actually allow sufficient visibility of the engine block to make a good decision about whether or not there is a need to remove the engine cowling or not? Thanks in advance.
