- Sep 7, 2024
- 3,501
Hello MH,@Auto Doc's: Even if they inspection port kits could not be used as cleanouts, I would LOVE to have such a kit on my Cub Cadet, so that I could inspect for mouse nests w/o having to take the engine cowl off.
Do you know if these "inspection cutout kits" are still available?
Do they actually allow sufficient visibility of the engine block to make a good decision about whether or not there is a need to remove the engine cowling or not? Thanks in advance.
I do not know if they are still available, but I will do some checking around.
Initially, they were simple metal templates held on with self-tapping screws, then Kohler came out with an updated fan shroud design that had nut plates, so the screws would not strip out the holes in the plastic.
