2005 Dixie Chopper Silver Eagle 44" Spindle Repair Issue
Jaxondaweb
  • / 2005 Dixie Chopper Silver Eagle 44" Spindle Repair Issue
Hello everybody, I just found the forum. My center spindle bearings are shot. I removed the spindle and there is a silver disc with 2 Allen Head screws that I removed. The disc looks like it should come right off but I have tried prying it with a screw driver and pounded on the spindle and it is not budging. Any ideas how to get this thing lose? It is not rusted. The silver disc has two holes in the top of it. Does this require some sort of special tool? Photos attached. Seems that I can't attach the photos because they are too large file sizes. Thanks, Steve
In 2005 - 06 there were spindles made in So. America. They were metric had set screws in the top disc on the side of the disc and the disc would screw off and on and the bearing consisted of an inner and outer bearing race and the seal was separate from the bearing. My 2006 has them. All of the components can be purchased from a commercial equipment bearing company and they are easy to reassemble. They are also adjustable like an older automobile front wheel or trailer hub. My suggestion is to buy a complete replacement hub unless you are mechanically inclined and understand the hubs on a trailer or the front wheel bearing on a 76 Corvette. The newer bearing sets are sealed and the grease fitting is almost useless you remove the inner seal so that grease from a grease gun to reach the bearing.
jaxontheweb
My 50" 2005/06 2750 had the old style hub that had 3 set screws in the side of the upper flange, "Old Style assy was used when the South America plant (think it was Brazil) was being used. The screws come out and you have to unscrew the upper hub and then the lower bearing assembly comes out the bottom. Some folks just buy a new hub but all that is necessary is to replace the bearings and seals.
jaxontheweb
Not all of the spindles are the same some were made in SA (Argentina I think) and they are threaded on the top as well as at the blades. There may be 3 screws but the disc should come off the spindle like a nut. and the bearings are replaceable and adjustable. Take the blade off, remove deck to spindle bolts and take the spindle assy to the bench and disassemble, clean and replace bearings. Adjust the bearings and put the spindle assy back on the deck. Check the bearing adjustment after the 1st or 2nd cut. You should be able to adjust on the deck without the belt attached.
hlw49
302585 Dixie Chopper Spindle short. $156.84 These spindles are non-greasable.
jaxontheweb
