20 HP Wierd oil leak
Ohh its one of those, I've got one Just like that. 1. Is the oil overfilled at all? I use some heavier oil because these engines are so old and mine has low compression. How much oil is coming out? It is normal for a mist to come out.
Considering this is a 24+ yr old engine there is a good change that one or both exhaust valve guides are worn out.
When I started professionally service Briggs engine back in 2009 I received a lot push mowers that swore had bad head gasket when it was only the exhaust valve guide. Dont see many L heads now days. Back then you could get after market replacement guides.
If you still can't find the solution for this person here the same thing has happened to him, read the comments, maybe something they told him will work for you
