20.0 Honda Engine on Hustler Zero Turn leaking oil from bottom
jayvee53
I have a Hustler Zero Turn with about 1500 hours on it and recently the Honda engine has been leaking some oil from the bottom in the area of the vertical shaft. I tried to include a photo, but apparently "it's too large to process". In any event, I am assuming a seal or gasket has failed. Any help on this would be appreciated. Thinking about tackling a repair over the upcoming winter. Thanks!
