So wanted to do a bit of a summary on what I found at my local dealers. This is pretty much the order I have them in from best to worst for my needs. All of them have pretty much the same financing options.
1. Ferris 400S (5901705), 21HP Kawa, 48" DECK $4499.99 sale pricing
- chassis suspension in rear, suspended pivot front axle.
- hinged seat plate with with heavy spring, super thick padded seat bottom.
- pegboard adjuster for cut height with 1.5-4.5" range 1/4" adjustment
- 20" drive tires
- Armrests
- Deep Fabricated deck
- Hr Meter
- Fuel level guage
- ZT2800 Transmission
- 4yr/500hr warranty
- CON: ~$2524 powered bagger.
- CON: farthest dealer to reach.
- CON: parking brake lever seems flimsy, same style/material as throttle lever but lot of tension on it.
2. Kubota Z121SKH-48, 21HP Kubota, 48" DECK $4979.00 sale pricing
- suspension seat
- Dial adjuster for cut height with 1.5-4.5" range 1/4" adjustment
- tall and wide drive tires 22x10
- ROPS
- Armrests
- Lights
- Hr Meter
- Fuel sight window
- ZT3100 Transmission
- ~$800 non powered bagger optional.
- 4yr/300hr warranty
- easiest to reach dealer, between work and home.
- CON: price +$400
- CON: No powered bagger option at all.
3. SCAG Liberty Z SZL48-22KT, 48 22hp Kohler, 48" DECK $4499.99 sale pricing
- Std lawnmower seat on hinged spring plate.
- Pegboard for cut height with 1.5-4.5" range 1/4" adjustment
- 20" drive tires
- Hr Meter
- 5yr/750hr warranty
- closest dealer, 3 miles from home.
- CON: No suspension seat or arm rests
Sounds like a great machine. The pegboard deck height selector is pretty much standard for most of the more robust residential ZT machines and many commercials.
Very true, so simple it pretty much cannot break. The SCAG I looked at had the same thing. That is the one thing that Kubota has over some other brands is that they have really good Ergonomics, but you pay for it as the above shows. Given my property the suspension really is a huge selling point, probably more than it should be, but with the amount of time and frequency we have to move comfort is important.
I would buy a motorized pull behind vacuum on a trailer long before I would spend $2500 on a bagger unit for the mower! The pull behind would be half the price and have 2X the capacity!
There is a $400 rebate on the 600 and up models. Not sure if that gets you closer to your budget. Rebate ends May 26.
I agree, the price I was quoted on the bagger was just crazy. To the point I have gotten the wife convinced to give it a go without bagging to see how it goes. I called around and found a deal 100mi away that will sell the bagger for $1800. I am wondering if maybe my local quoted the Turbo-Pro Max or even the Fast-Vac, I will have to have him check as everyplace I have looked online the bagger for the 400S is $1800.
I heard about the rebate. If the 600 got me the ICD deck or independent front suspension for the extra $ then I would think about it with the rebate in play. But for some reason Ferris chopped both of those off the 600 for 2018, they honestly downgraded the unit quite a bit this year which baffles me. For the extra $ you get ROPS, bigger tires, better Hydro's. All have value, but it does not seem like there was a price drop this year and they took away 2 huge high value features. imho they should have dropped the hydro's down a notch(2800 still a good unit from my reasearch), nuked the ROPS and kept the ICD and independent front suspen. As usual I am a year late
I will have to see if they have any 2017 IS 600Z's around still.
