I have a 17.5 briggs in order to get it to crank I have to hold the throttle at idle to get it to even crank when it cranks it runs great at idle but when given gas it starts to surge. I can bring it back to idle and it runs fine. I have put another carb on it I have soaked it in a five gallon bucket of carb cleaner for a least two hours sprayed it down with starting fluid and blow out with air compreser but still no change. I have adjusted values to specs and pulled motor down and checked the governor. I cant figure this one out can anybody help any ideas what could be the cause of my problems.
