16.5 hp Briggs and Stratton I turn the ignition switch and flywheel only turns 1/4 of the way around and stops. If I keep turning the key eventually it will start and run strong . 2022 a new battery, solenoid ,ignition switch its started normally from Oct 2022 until May 15 2023 now its acting up again . I ordered a new coil .
Check valve clearance adjustment, especially if overhead valves. All of these type loose adjustment and severely disables the compression release on startup. Normal valve clearance is small and subjective to wear. Briggs and Kohler
