No put the fluid in the air intake. The jet is the thing in the middle of the float it's the hole where the screw goes. You need to spray with carb cleaner or blow with compressor. When you test for spark take the plug out and put the wire back on and then put the tip of the plug on something metal like the shroud and turn the engine over watching for spark if spark great if no then take the shroud off and pull off the kill wire to the magneto and try again if no again then you have magneto failure and that would be your prob. If you have spark and you try the spraying starter fluid then it might be a valve or timing issue but I do not think this is the prob in this case. Cheers
