- Nov 29, 2014
- 24,995
Modern fuel is conductive at cylinder compression pressures
Modern fuels will leave an oily residue on the spark plug nose
Electrical resistance increases with pressure .
So it will spark beautifully in open air but in the engine spark will track down the side of the plug following the path of least resistance
This is why you hear that a good magneto will throw a 1/4" to 1/2" spark ( or better ) outside the engine yet the gap is only around 0.030".
