126M02-6675-F2 Won't Run - Replaced Carb & Flywheel Key - Still No Go
  • / 126M02-6675-F2 Won't Run - Replaced Carb & Flywheel Key - Still No Go
Unless specified by the customer they get NGK's because they are 50¢ cheaper & I charge the same price for all plugs.
NGK's also come in 10 packs & Champions or Bosch come in 4 packs or 10 x 4 packs
Same grades as Illengine unless there are signs of the engine needing a hotter plug.
OTOH
No 1 rule in engineering " if it ain't broke, don't fix it "
As such I would be lucky to change more than 20 plugs a year out of 300 or so jobs
I expect 50,000 to 100,000 miles out of my car plugs
I have plugs in engines that have not been changed since they were made and some of them are near 100 years old from the days of 2 piece plugs .
My truck plugs burn out and start causing issues around 40,000 miles. Oh guess what they are OEM Champion plugs. Because they are an OEM only available through the dealer plug.
Yes plugs can spark outside the compression zone but under compression fail to fire. I had one air compressor years ago that would run fine and build up pressure. It just wouldn't restart if the air was full and it turn out to a bad plug. It had me nearly pulling out my hair as to the cause.
Bert, Most of the NGKs I buy here comes 4 packs. Now some do come in 10 packs but they are usually the 2 cycle plugs.
And IL I have a lot failures of the 10mm CMR series NGK plugs which I am replacing with Bosch plugs but in the long run most plugs are fairly reliable.
Even new plugs can fail straight out of the box.
SamB
OTOH
I don't just change my mower plugs out of boredom. Like you,bert,if it ain't misfiring or hard to start,I leave the plug alone!
