Yea that makes sense. So i did put some starter fluid direct into spark hole, put plug in and pulled it. There was a kickback so violent that the handle was jerked out of my hand....and i let out a yell from the ensuing pain that could be heard a block away. What does this mean?
If it was just a kickback, that means you just got to the compression stroke and it was too much for you to handle. Did it fire at all?
One thing that means is that the piston is still connected to the crank.
