toro zero turn 76601
Auto Doc's
Hi slomo and StarTech,
Thanks for uploading examples. Many of our followers are not aware of these strange testing methods that are used to verify carburetor needle a set sealing effectiveness.
bear369
dad emailed me today.. it is a KT 715-3098 we have cleaned the shroud and cooling fins of all grass clipping.. but very little debris under the engine cover.. thanks for your help..
Something us wrong here as the KT715 is a 20 hp engine and Toro says the mower is suppose to have a 26hp which is the KT745.
What is the engine's serial number? I can use that to get Kohler to look it up.
