Changing Transmission Oil
Keep in mind that hydro fluid is hotter than engine oil.
I'm all ears. Please explain.
A fluid is a fluid is a fluid. The additive pack in motor oil or even the base of it will reach the same temp in said system as regular hydro oil. What did I miss? Thin or viscous at 212F is just that.
Skippydiesel
I have just replaced the stinking mess (oil) that came out if a Tuff Torq K46 V with full synthetic, Penrite HPR 10, 10W-50 motor oil. No word from the customer at this time but hope it will give the, 30+ year old , mower a few more operating hours.
kbowley
Both Tuff Torq and Hydro Gear recommend 15-50 or 20w50 full synthetic API-certified oil for their sealed units. Personally, I use Mobil 1, but any brand-name oil, such as Pennzoil Platinum, Rotella, etc., is fine. Wheel Horse, Cub Cadet, early Bolens, etc., with the Sunstrand or Eaton pumps, use 10W30 synthetic or conventional. I use what the manufacturer's recommend; they are the ones that engineered and tested the units. If you are uncertain, simply call the company and ask them what they recommend.
Ozcub
Change the oil and go for a Full synthetic 20w/50 and it will be as sweet as a nut for another 100 hours then do it again , you and the hydro will love it and the hydro will last a long time
Oz
Do the Forum members think there is any benefit in changing the hydrodrive/transmission oil on a Toro Wheel Horse 17 hp?
(FYI mower performs very well but in the past I have had a hydraulic transmission fail & have always wondered if a timely oil change might have extended its working life)
Should the consensus be, it would be beneficial to do this - any thoughts on best oil for the job?
I realise that this may require the transmission/transaxle being removed from the mower, as there does not seem to be any provision for draining the old oil.
You might want to pick up a suction hand- pump canister to make that oil extraction way easier. Surely beats the alternative! I'm sure you can find one any number of sources, but I bought mine several years ago from the DR Field and Brush Mower folks back when I owned one. It's the kind of tool like a faucet wrench - it lays there and gathers dust until you need it. Then, one day, you need it!!!
