Hi Russ,
The engine is a Kohler CH-25 Not a terrible engine I was very surprised to find things like roller lifters.
I wish it had about 50% more HP. The displacement 750cc is ok, but more torque would be nice. A friend has a turbo charger that came on a motorcycle that he wrecked a few years ago, it could easily add an additional 10 HP.
The deck was really trashed and required about 30% of it's steel to be replaced, while I was fixing it I reinforced all of the week areas and made it so water and moisture could not be trapped. All of the irregularities on the under side were smoothed out with Kevlar reinforced epoxy that was applied to the freshly sand blasted and acid treated steel. Then I gave it three full wet coats with KBS Rust seal. They turned out very glossy and should stay that way without top coating due to the lack of UV from the sun.
I used that stuff on a 150yr old cement mixer 6 years ago. After mixing almost 200 - 80lb bags of concrete in the thing, the paint is still perfect, although it has chalked some (I didn稚 top coat it) in addition, it has not even worn off the ring and pinion that turn the barrel.
As usual, time will tell. The reason I am so paranoid about rust, is the mower will be parked out side under my deck with little more than the protection of a good tarp.
I'm 74 and figure that if I'm lucky I will need the mower to last no more that 10 years.
Since I quit drag racing a 9 second car last year, I guess I'm looking for an "E" ticket lawn mower to keep my adrenalin flowing. Possibly, I should be looking for a 1000 cc motorcycle engine. Ha ha.
I have not heard of E-Zlide, sounds interesting, I知 going to look into it today.
Thanks Russ
Pete
