turfboy1997
- Apr 24, 2012
- Threads
- 26
- 164
Well I got this mower off eBay two weeks ago and it has been a chore! There was slop in the bearings so I cracked it open and put in new bearings and crank seals and cleaned the piston and exhaust ports. I cleaned and reinstalled the rod bearings and degreased the whole engine and RTV sealed the two halves. I installed the new capstan gasket and put In a new PTO seal. It runs really well but the plastic carb is a little fickle on adjustment. I installed a new needle and seat, bowl gasket and carb to block gasket. I greased the capstan, removed all the rust off the chrome using wet aluminum foil and rubbing. The one great thing is the original battery holds a 14 volt charge! So I did not have to rebuild the battery! I am just in love with these F motors! They are so smooth and easy to rebuild! I did the complete rebuild and had it running in two hours! Best of all it is tight like it just came out of the box! Hope you enjoy the pics!
