Heating your house
reynoldston
It just got to the point that heating my house with fuel oil anymore is gotten out of sight. I now have to pay 4.00 dollars a gallon for heating oil. I have installed a insert into my fire place and heat with wood. I have 5 acres of woods and get some of my wood from there. I have found I can be very comfortable now and not worry what it is costing me to keep my house temperature around 80%. I also find I am not the only one that enjoys the heat.
scott47429
i also heat with wood i have a wood stove i put in 3 years ago and i love it i get my wood from my brothers woods sometimes or i have a tree trimmer that gives me all the wood i want if i go pick it up at his site hes cutting at it took my electric bill from 600 a month for the 2 coldest months to 200 bucks a month pretty much all winter long so far i havent spent any money to buy wood other then what i spend in gas and oil for the saw and truck so its pretty cheap 3 years ago i had two months in a row of 600 a month heating bill i spent 1400 to put in the stove so i figure it paid for its self the first winter
okiepc
I have been heating my house for the last 23 years with 75% wood heating, on really cold mornings I will kick on the gas heat to take the chill off then start a fire. I love wood heat, like cutting and splitting as it helps keep me in decent shape, no down side for me.:thumbsup:
Carscw
On very cold mournings I fire up the propane heaters. Only used 25 gallons this year
Sent from my iPhone using LMF
reynoldston
25 gallons wouldn't go very far here in northern NY. When it below -0 I also fire up the oil furnace in the morning to warm my floors up.
Carscw
I remember using a oil furnace growing up on cape cod. Down here they have no clue what a oil furnace is.
SeniorCitizen
I suspect the same thing could be said about up there and propane . :laughing: And you would really loose them if you said you were going to air your tires with propane.
Parkmower
I have a similar insert and was wondering if you have s liner and what size and material.
I have no liner. The fireplace damper was removed. It's an interior chimney that is brick and the chimney the woodburner uses is 12"x12" with a stainless cap. A sweep that I had look at it and cleaned it when we moved in. He removed the old damper and said it had great draw and just have it swept every 4 cords. I Only burn occasionally but would like to burn regularly and thinkin of maybe installing a liner. It hasn't been swept in 5 years but I haven't burned more than 2 cords in that time.
Any thoughts?
Carscw
Very true.
reynoldston
I have no liner. The fireplace damper was removed. It's an interior chimney that is brick and the chimney the wood burner uses is 12"x12" with a stainless cap. A sweep that I had look at it and cleaned it when we moved in. He removed the old damper and said it had great draw and just have it swept every 4 cords. I Only burn occasionally but would like to burn regularly and thinkin of maybe installing a liner. It hasn't been swept in 5 years but I haven't burned more than 2 cords in that time.
Any thoughts?
I did my home work when I install mine. The old fire place damper was also removed from mine and my chimney is brick with a 12X12 tile liner. My wood burner has a 6 in. stainless steel chimney liner insert with a cap on top which I bought as a kit with the heater. The hotter you can run your chimney the better everything will work. I burn over 19 in. long 12 face cord a year and clean my pipes every other year so that is 24 face cord between cleanings. I am running mine hot in the day time and cooler when I go to bed and it never goes out. I try to keep 3 to 4 ins, of hot charcoal to run my fire in and only clean out the ashes once a week and that is only about a haft of a steel pail of fine ash a week. In the real cold weather I will run my oil furnace for a short time in the AM to heat my floors. I like my house warm but if it gets too warm I open the windows to cool it off. I do cut some of my own wood but have found I buy most of my wood from a person that cuts wood for a liveing and only charges 65 dollars a face cord and for that type of money its too much work to cut much of my own.
