EngineMan
- Jun 12, 2012
- 2,275
meter should read (0) not move, if it does you have continuity, remove purple lead from key switch and try again, if you still get continuity one or more of the safety switchers are closed making the path to earth, so check them, or the coil is bad and needs replacing.
I need to go out and do some shopping so will be away from PC for about an hour, but will be back later.
