natenkiki2004
- Apr 22, 2011
- Threads
- 13
- 177
natenkiki2004, check the linkage and the return spring, you can bend the tab on the front where the spring attaches to slow the RPM's
Thanks, I just saw the tab up front with the spring. I bent the tab the equivalent of 1/8th of a turn away from the engine (tensioning the spring) and that didn't seem to have any effect on engine speed. Do you have any idea on the proper RPM for this engine? I'll get a tachometer sometime and see if my worries are founded or not.
