Charles_cz
Hi guys what should I check first?
Today I have noticed that my battery light on Cub Cudet 1050 LTX vent on when PTO engaged. When I shut off blades light would disappear. I assume it just indicated low voltage when PTO engaged and when I turn blades off it voltage came back to certain limit to turn the light off.
After some more cutting the battery light would stay on all the time as battery was used and not charges I assume. When I turned off the engine I could not start it anymore as battery was drained completely.
I just removed the battery and it's recharging.
1. Is alternator my problem? Does it have separate alternator? I can't find it. :frown: What else should I check?
2. Am I going to damage anything if I try to finish my work toady after I recharge the battery? I don't need light or display working etc. I understand it's not probably good for the battery.
Oh.. and it has Kawasaki FR651V engine.
Thanks for advice. Charles
