Oil change mess, suggestions?
Late this summer I bought a new 48" Toro Titan with the Kohler engine. Planning on doing the end of season service and will be running into the same problem as my previous (bought used) zero turn mowers. Unscrew the oil filter and oil goes all over the place on the engine deck. That leaves an oily mess no matter how hard you try to clean it up as the oil goes to inaccessible areas. The other mowers already had this oily mess under the engine, I would like to prevent this with my new (and clean) mower.
Other than stuffing a bunch of rags or paper towels under the filter while unscrewing it, and that isn't a guarantee oil won't go all over, any other suggestions to minimize the mess? Thought about jacking up that side of the mower to try and partially drain the filter, would that work?
Just like a boat and trailer. As long as you can get the boat off the trailer the manufacture couldn't care less if you can get it back on the trailer.
I have a Toro too. Timecutter. I get the same mess. Its just the nature of this machine; they didn't see fit to make it un-messy. I just wash it off with a water hose, wipe it down and go. Its a mess, yes, but there are some good suggestions made by others. I like the flexible oil filter idea BUT getting it to stay in place while you unscrew might be trouble.
No drain hole in the area under the filter and not much, if any, room to put a catch pan under the filter.
That hose that travels down and left in the photo, should be the answer. It looks like an oil drain hose. If there is a plug on the end of that hose, open it and the oil should drain out.
It will take two wrenches, one to hold the hose from twisting, and the other to twist open the plug in the hose end.
The issue he is talking about is when you unscrew the filter. It is a mess. But, you're right. That hose is for draining oil from the engine. I bought one of those from a Toro dealer and put it on my Toro. Its slow but its far less messy.
