Oil change mess, suggestions?
Lots of suggestions for using/forming a “funnel” to direct the oil away. As previously pictured there isn’t much clearance between the filter and the engine mounting deck. Wouldn’t be able to get much slope, plus where would I drain it to? The hole by the filter and drain hose is directly above the hydro so no room for a catch pan under there.
Probably use paper towels or as also suggested, absorbent mats, under the filter as I unscrew it.
Yes, many ZTRs are not service friendly. Poking a hole in the filter as previously mentioned is my go to. It allows a couple ounces anyways to bleed out. The bag over the filter once it is loosened is a great idea.
Cut down a side edge of a foil baking pan - slide the cut down edge under the filter.
