Mower has ran great til 390 hours.suddenly instantly shuts down when mowing. It took about 1 or 2 hours of use before it started having this issue. I took to dealer and got run around for weeks couldnt recreate issue. I replaced coils/plugs/fuel pump fuel filter..... same problem :/
Called exmark area manager who said goto a different dealer half hour from your home and they will resolve this.
They did! Within 2 days they replaced pto switch, mowing side wire harness,(not engine side harness) and the pto clutch. I had no trouble since then and 150 more hours and one hot day after about 1.5acre mowed it shut down while active mowing.
I started cheap... coils,plugs,fuel pump,fuel filter, same trouble...
My question to yall is, would one of the 3 parts replaced by dealer be your likely culprit? I am out of warranty and will have to handle this myself :/ would like to save as much $$ as possible not throw too many more parts at this thing... any help appreciated
