Exmark 2blade 48" cut- Exmark brand motor (24hp)
Scolabird
Mower has ran great til 390 hours.suddenly instantly shuts down when mowing. It took about 1 or 2 hours of use before it started having this issue. I took to dealer and got run around for weeks couldnt recreate issue. I replaced coils/plugs/fuel pump fuel filter..... same problem :/
Called exmark area manager who said goto a different dealer half hour from your home and they will resolve this.
They did! Within 2 days they replaced pto switch, mowing side wire harness,(not engine side harness) and the pto clutch. I had no trouble since then and 150 more hours and one hot day after about 1.5acre mowed it shut down while active mowing.
I started cheap... coils,plugs,fuel pump,fuel filter, same trouble...
My question to yall is, would one of the 3 parts replaced by dealer be your likely culprit? I am out of warranty and will have to handle this myself :/ would like to save as much $$ as possible not throw too many more parts at this thing... any help appreciated
How long between getting back from the dealer and problem reoccurring? Whe it shuts down have you checked for both spark and fuel? Post engine numbers so we can see what you have.
The intermittent-ness is the problem once it dies ... and i hop off n check fuel its good. I check spark, and it seems fine. Yet something is causing a random and immediate shut down. Doesn' t actually remind me of a fuel restriction, as when it dies it will only do it when blades are engaged and IMMEDIATELY! NO SPUTTERING!
I WILL GET MODEL # ETC... BUT NOT AT THE MOWER RIGHT NOW.
ASSUMING ITS SPARK/ KILL CIRCUIT RELEATED do ANY 1 OF THE DEALER REPLACED PARTS SOUnd more accurate than another, to yall??
You may want to take it back to the dealership that fixed it.
If it's the Exmark that I think it is, it's just a dolled up Toro Timecutter. They have that dumb reverse/brake switch box that can mess up and cause all sorts of problems. They also use the cheapest safety switches that can be found.
Take it back to the preferred dealer.
Had it back say a year or so :/ dealer says im out of warranty, oof. 708cc engine.
Well i do have a pile of cheap Toros... this mower (while a cheaper entry level model) def. has a bunch more wiring and a seperate proper parking brake that locks it unlike the timecutters that u simply put handles in park.(if thats what you were describing) could the safety switch simply be the pto engagement switch the dealer replaced??? Any troubleshooting tips i can try maybe with a multimeter, on switch or on pto clutch itself?
It could be any number of things. Throwing parts at it isn't the answer.
Have you checked the wiring to the fuel solenoid? A broken or chaffed hot wire to the solenoid will definitely cause this sort of problem.
Is the engine cooling fins clear of thrash and buildup?
Trash in the fuel tank can cause this sort of problem. The trash will slosh around until it finds the pickup tube.
If you know your way around electrical wiring, get the wiring diagram, a check light, and multimeter and have at it.
If not, take it back to the dealership that you used before.
The dealer already threw three parts at this mower. I don’t know that I would rush back to this same shop again.
The second dealer seemed to have fixed the original problem.
See the original post. He says that he put an additional 150 hours on it after the repair.
Blow up the second picture. Do you see the oil and debris buildup on the cooling fins?
Yes the problem went away after new pto switch/clutch/wire harness..... but the mower also got a lot less daily use as we bought another mower to offset any shoptime
