Husqvarna Zero Turn 54 inch rear tires
USMCSGT323
Can anybody tell me if I can put wider rear tires on my Husqvarna zero turn Z254 mower to try to improve traction and if so, do you have any recommendations for a tire type or model? I live on a hill and I find myself constantly spinning and digging ruts throughout my yard. thank you for any help you can provide.
Rocky J
If you are wanting to increase the weight per square inch of tire for better traction you would want to go with a narrower tire . The weight of the machine will not change in the math so for example tires are 10 inches wide times two is 20 inch of tires and machine weighs 500 pounds ?? would be 25 pounds per sq inch . By going with 8 inch tires it would be 31 pounds per inch . I have had ATV tractor tread tires and you have to take turn arounds a little less aggressive or you end up with big spoon digs at the bottom of the hill starting back up but they do not spin like the turf tires do leaving the greasy green burn outs but roll the sod down to the black dirt .
Auto Doc's
Hi,
Zero turns are not very good on hills usually unless going straight up and down them. That is not always possible.
Wider tires also means slightly taller profile. They may actually be worse. The deck height would have to be adjusted slightly to compensate for the pitch of the mowing deck.
I recommend you first lower the tire pressures slightly and see how it works. Often times tire pressures are not properly set when new. When new, the Z-Tracks come on a steel frame ship crate and tire pressures are set high so they can be strapped tightly. During setup, many setup guys just overlook tire pressures and do not correct them.
This model calls for 15 PSI on all tires but lower the rear tires on yours to 11 PSI and see if it reduces the spinning and rut issues.
If the hills are too steep. you may want to consider changing rear tread design to more of a flat bar grip design.
Honest Abe
maybe a set of these..... Marastar Turf Traction, they work great on my slopes​
USMCSGT323
Hi,
Thank you for your response!
USMCSGT323
