Switching to longer blades?
Honest Abe
Well that would leave no overlap; unless, BB is lying about the cut width as 3 x 24" is exactly 72". I have yet to see a mower with no blade over lap.
Stihl does lie about the bar length on their saws so maybe BB is taking up the same habit.
actually I guess it's all dependent upon which Bad Boy dealer site one uses....
I just Googled this -
and it shows 24.218"
Hmmmmm..... :unsure:
That gives 24-7/32" or basically just over 3/32" overlap between the blades.
MParr
24.218" from blade tips to blade tips.
BigBlueEdge
Bad Boy 72" deck use 24" blades...
also, have you check the tire air pressure to make sure they are all up to spec...?
Yes, tire pressures are at spec. How would tire pressures affect cut quality?
MParr
The tire pressures must be set before making leveling adjustments to the deck.
Douglas Lee
I had a simular problem with a 40" Gravely deck, I slotted the mounting
holes in one of the spindles to move it closer to the other blade.
Thanks,
Douglas Lee
BigBlueEdge
Sure. But my issue isn't a 'level' cut, it is uncut/poorly cut strips of grass where the blades meet.
BigBlueEdge
if the pressures are way out of range from one another then the deck can't be level....
This thread isn't about leveling the deck. Not sure how that has become a focus. The only reference to 'level' previously was about front-to-back tilt where someone suggested there shouldn't be any.
