BigBlueEdge
- May 27, 2015
- 115
Wide F'n open throttle. Mowing speed doesn't really have any effect for me unless I'm virtually crawling along. Any normal mowing speed gives me these results.
You would be surprised. There is no one deck setting to fit all. I have a Gravely Pro Turn 260. Gravely says to set the rear 1/4" to 1/2" higher in the rear. It doesn't do well anywhere between those heights. I wound up with the rear 1/8" higher than the front and it cuts beautifully.I do. The OEM blades did this and the appropriate Gator replacement blades do this.
As for level, I have it set per Bad Boy's recommendation, which I think is about 1/4" higher in the rear. I highly doubt a 1/4" difference over 24" would magically fix my stripe problem, would it?
OK. I can level the deck front-to-back and give that a try.You would be surprised. There is no one deck setting to fit all. I have a Gravely Pro Turn 260. Gravely says to set the rear 1/4" to 1/2" higher in the rear. It doesn't do well anywhere between those heights. I wound up with the rear 1/8" higher than the front and it cuts beautifully.
Do you know what the blade length should be for a BB 72" deck?It won't be the first time for BB to spec the wrong parts. I got a customer with a 2017 Magnum that they say the short brake cable is the correct one. Not in my opinion when you can play a tune on it installed. Found the longer cable with no help from BB tech support. Awaiting the customer to return the mower for me to exchange the cable.
No I don't than the PN refers to a 24-1/8 blade which is just over 72-3/8 when you multiple by 3. There is no margin for error at this measurement. There should more overlap which is why I asked about the tip to tip and tip to deck clearances. It makes more sense to have 24-1/2 blades but got to know the clearances and I don't a BB mower in the shop with a 72" to even look at, just a 54". Even a 24-11/16 or 25" might work in aftermarket [ie for another OEM] but it is all a guessing game without the measurements.Do you know what the blade length should be for a BB 72" deck?
Well that would leave no overlap; unless, BB is lying about the cut width as 3 x 24" is exactly 72". I have yet to see a mower with no blade over lap.Bad Boy 72" deck use 24" blades...
also, have you check the tire air pressure to make sure they are all up to spec...?
