BigBlueEdge
- May 27, 2015
- Threads
- 7
- 95
Has anyone tried running blades that are a bit longer than the standard/recommended blade length for a particular model? On my Rogue 72" I've always battled two 'mohawks' of grass at the point between the three blades. It's not awful, as in completely uncut strips, but it is pretty noticeable everywhere as being two slight strips that aren't as flat as everywhere else. I was thinking of trying some blades that are just a bit longer than the stock "24 inch" blades to get a bit of overlap. Of course I'd ensure that the clocking of the blades is such that they never meet and touch each other. I haven't actually looked to see what other lengths are available, so maybe this idea is bunk if there are no ~25" blades out there...
I'm unsure why my Rogue behaves like this. It has occurred with both the stock blades and Gator G6 blades. I can't believe it is some type of adjustment and I know for a fact this occurs when my blades are freshly sharpened.
