- May 6, 2010
- 12,021
Sheared flywheel key in this won't prevent spark. Would effect starting and running but will still produce spark.Grounded the plug. No spark. disconnected the "kill" wire. No spark. Coil installed correctly. It's marked"out". I don't think you could make the electrical connections if it were installed upside down. Didn't hit anything. Will try and check the crankshaft keyway, it's a long shot but who knows.
