B & S engine size.
GreerFarrell
Hello all. I was wondering if somebody could clue me in about a B & S engine size (ccs, hp or cu. in.). The engine code is 124682 0112 01 010616 FA. It is an Intek I believe made in 2001. It was driving a self propelled mower when the con rod shattered at the bearing cracking the flywheel end of the case.
Any help would be greatly appreciated.
190cc (6.5hp Gross)
From Briggs​
Replacement Engine Information​
Replacement Engine:NO REPLACEMENT ENGINE IS AVAILABLE
Replacement Shortblock:No Replacement Shortblock is available
691457 Crankshaft PTO end specs
GreerFarrell
Thank you Star Tech for that helpful information. As I mentioned the fly wheel end of the housing is shot as is the crankshaft and conrod. But everything else looks in good condition. I may have a crack at picking up an old 190cc B&S engine without the PTO then, like Frankenstein, cobbling something together. I really liked this mower (Rover) and would like to keep it going if possible.
Greer.
GreerFarrell
190cc (6.5hp Gross)
From Briggs​
Hey Star Tech,
Given those diagrams and dimensions you posted am I correct in thinking that the basic upper crankshaft dimensions are consistent across these 190cc (6.5 hp) motors but there are variations in sizing and configuration when you exit the lower crankcase?
Thanks for any information,
Greer
Auto Doc's
Sounds like time for a repower engine from small engine warehouse or a Harbor freight clone
GreerFarrell
Many thanks for the reply, however this particular motor has an auxiliary PTO (driven by the cam shaft) that exits the lower crank case, powering the (chain driven) self propelled mechanism. I am pretty sure there isn't a replacement motor available.
Auto Doc's
Do an internet search for Briggs and Stratton and your first 6 numbers you listed. The block still shows available through Jack's Small Engine. Not sure about any other parts damaged that are no longer made.
Kind of unusual to find this design was still made that late. They were more common back in prior years.
