Leak from bottom. I have a GH 526v/52 that has an oil leak from bottom of engine area.B&S 26 Hp Engine.
lowmow
  • / Leak from bottom. I have a GH 526v/52 that has an oil leak from bottom of engine area.B&S 26 Hp Engine.
Leak from bottom. I have a GH 526v/52 that has an oil leak from bottom of engine area. Cannot find source of leak. B&S 26 Hp Engine. Can engine oil seal be replaced without removing engine? If not, can someone please provide guidance on removing engine?
Thanks in advance for all time and assistance on this problem.
Rocky J
I have replaced them without removing the engine. Remove your pulley /PTO clutch , drill a small hole into the metal of the seal , Install a screw into the drilled hole and use a claw hammer to pull out the seal. Use a section of 1 1/2 inch PVC drain pipe 6 inch long or longer as your seal driver to install the new seal . I have had to change a few sump gaskets on them . The gasket is not pushed out but was sucked into the pan. They sell a Dye to put into the engine oil that will glow with a black light to find the hard to find leaks.
common sence
Some can some cannot. If u have to ask about how to remove engine I’d suggest don’t try Without help.
lowmow
There are many ways to skin a cat as the old saying goes and I can pull the engine. I figured that people with many years of experience might have a shortcut or easy way to do it. A friend showed me how to replace a throw out bearing and clutch in a truck without having to put a 500 pound transmission on the ground or use a transmission jack.
No substitute for experience, and I do not repair mowers every day like some on this forum. You guys are great, and I can access a total of more than 100 years of experience here.
I am never too old to learn.
lowmow
Can anyone provide a complete, legible electrical schematic for a GH 526v/52?
Most I have seen are blurred in the finer details. Thanks in advance for all help on this.
