Tiger Small Engine
- Dec 7, 2022
- Threads
- 3
- 1,437
Here is one other trick you can use, provided the spindles clear the underside of mower. Also, may have to remove spindle safety covers to accommodate increased deck height clearance.Okay tiger I got you on that thanks for replying but I do recall getting on the ground and looking at that whole setup and everything was jammed up near the frame going up say towards the seat.
Jim
Remove the nut on the deck hanger rod and put in a washer(s) or bushing to give you more adjustment. If the threads are maxed out, this can give you another inch or so.
