jes_in_sac
- Sep 7, 2024
- 23
My mower is only for the grass and weeds, since there is no lawn on the farm. I tried everything... tubes, slime... but finally, the only thing that worked was lugged tires on the mower. Haven't had a problem with either of those rear tires since, and that's been probably 15 yrs ago. Now the front tires, they are always a pain, and I should find some lugged tires for those too, if they make them that small.
Get yourself a mini-tire changer [fairly cheap at Harbor Freight]. It won't keep the tire from picking up stuff and going flat, but at least it makes that part doable. I just clamp it in my vise on the bench to work on those small tires. I think that I'm doing plugs from now on though, since I haven't had much luck with inner tubes, and actually took them out of some of my tires, since they ended up being even more trouble. I don't trust plugs on high-speed tires on a car, but on a mower tire, it's got to be easier up front and easy to fix if it pops out again. And yes, I have found slow leaks on the wheel itself from a porous weld. Loctite makes an anaerobic weld porosity sealer that works great on those tiny leaks in metal.
