Honest Abe
- Jan 18, 2013
- Threads
- 3
- 323
have you checked "PartsTree.com", it shows up for $108.99, but you'd have to call to be certain ..../
Hello Startech,In the middle pix it appears that you have worn completely thru the bushing so it need removing and the bore may need slightly resized to recenter things as you want the new bushing(s) to be making full contact. It also may just be the way pix looks here.
Now there might enough the steel busing to get the PN number off it for the manufacture of the bushing. The problem there is if anyone sells a small quantity of them. This is the problem doing a lot repairs as locals just don't provide us the parts like they did years ago as today's techs are a lot lazier than but in my early years of working on things.
Now is two bronze bushings will work, they should or you could go with a full length one and just drill out the material where the zerk goes. Just be aware that bronze bushing will not last long as the steel one so you need to check on it more often and make you keep it greased.
As for the bushing sizing is one you would need do on your end as I have never had one these arms in my shop so I don't have the specs from one I have done. But you should be able get the bronze bushings from Grainger.
according to the parts diagram, there shouldn't be any steel insert, just an upper "and" a lower bronze bearing...Hello Startech,
Sorry. The hub photos I sent are showing you the hub without the bronze bearings. I removed them. The new attached photos show you the two bronze bearings next to the hub. You can tell these bronze pieces are worn out to the point there is no material left on some locations. Now I think there is still a steel sleeve inside that hub. The photo ending with 42054 or 13507 seem to indicate it is there. I will talk to a machinist and see if he can help but I don't know what he do to reproduce the steel insert. He might need to machine a brand new hub. Maybe full solid hub that can accept the bronze bearings. There are no issues in ordering the bronze bearings. I am waiting on them to arrive from Scagpartonline. Once I receive the new bronze bearings I will be able to know the steel insert ID (bronze bearing OD).
Thanks so much.
Richard
IHi Hionest Abe,have you checked "PartsTree.com", it shows up for $108.99, but you'd have to call to be certain ..../
Yes. That's what I saw in the parts list as well. It's just weird that one end of the hub appears to have a steel insert which receives the bronze bearing. Maybe it is just a chamfered inner edge. I am wrong...Okay, now I see how it is assembled. The hub mates with the arm plate. The hub's machined end male OD fits into the plate's receiving hole and that's how the two aligned together. No steel insert in that hub. Just two bronze bearings.according to the parts diagram, there shouldn't be any steel insert, just an upper "and" a lower bronze bearing...
