VRR.DYNDNS>BIZ
Our record was 13 hours getting one off - a double stack with manual pto. when we get a drive belt replacement requesting a quote I exclude the pulley removal.I have done a bunch of these types by MTD. Do yourself a favor and unbolt the engine. If you heat it enough to get it off you will probably damage the lower seal. The hacks will bend the 3 belt guides but that just proves they are hacks. The pulley is paper thin so any prying ruins them. MTD uses that same crap pulley and stamped guides on lots of different makes and models. If you have already buggered the pulley be prepared to remove the engine to get it off. I did one last year where the pulley was worn out and needed changed. Wound up removing the engine and drilling a series of holes in a line and the splitting it off with a chisel along the holes. Broke a thread rod on a bearing separator trying to get it off.
