Bigdaddy's Craftsman
 - Jun 14, 2020
- Threads
 - 3
 - 27
You don't think i could get a head gasket and a new piston.
			How much do you think this mower is worth? What is the model number of mower? Age?What I see is damage to the exhaust valve seat and a broken valve. Also damage to the head of the intake valve with the possibility of the intake valve being bent. Also there are holes in the piston with the potential of the rod being bent. So I would with any potential of doing proper repair would require a new head and a new piston and rod.
Sounds like the exhaust valve guide has moved.Bottom, i meant Bottom valve. It would not move up and down.
Top valve looks good.
The spark plug has been out the whole time.
Internal, meaning what could it be.
