Help!!!! Troy-Bilt
Okay guys, I need some help.
This is driving me crazy.
I took the deck off of my Troy-Bilt Pony to change out both blade pulleys.
While I had the deck off I changed the upper and lower belts.
I tried to crank the mower to see how it ran with the new belts.
Well, I couldn't get it to start up.
I could turn the top with my hand but it stops when I try to go clockwise.
Starter is good.
So I changed out the carburetor and the solenoid back by the battery apartment. Oh and a new battery.
I just don't know what's wrong with it.
Thanks in advance
17.5hp 500cc 42"cut
model #13an77kg011
Bertrrr
So it does not turn over ? or doesn't start ? two different problems for the help you need
hlw49
Check the valve clearance. While you are at it check the compression release. Turn the engine over and watch the bottom rocker to see if it bumps off just before it reaches top dead center.
Turn the key on and it just click.
In order to check the valve compression, that means you would have to turn it by hand and my won't turn clockwise.
Scrubcadet10
Moderator
Staff member
did you raise the mower, in any way, to do your work?
Yeah, i had it raised most of the time. I took the deck out and changed both upper and lower belts.
I left the deck off
Yeah, it will roll 360 in any direction.
I just took the valve cover off.
I turned it by hand counterclockwise and then clockwise and the bottom isnot moving.
Bertrrr
By the bottom are you referring to the crankshaft ? is the piston going up and down ? , Pull the spark plug and watch your piston to see if it's moving, it should roll very easy with no compression , you can put a rod through the plug hole and watch it move with the piston , if no movement you got major problems internal.
Bottom, i meant Bottom valve. It would not move up and down.
Top valve looks good.
The spark plug has been out the whole time.
Internal, meaning what could it be.
