Skippydiesel
- Nov 29, 2020
- Threads
- 13
- 279
I would if it was my mower BUT here is a short list of what needs doing ;It should do better since the oil was burnt. But you at least replace that bad fan and clean the exterior of the unit. They are around $10.
- Extensive corrosion and paint loss
- Transaxle cooling fan broken
- Drive belt needs replacing
- Left cutter deck spindle bearings worn out
- Left front wheel bearings worn out
- Tyres don’t hold pressure
- Engine in need of a major service
- Cutter deck – heavy corrosion/badly dented and even “ripped” in places
The above list will go to the owner, as a condition report, with the advice to act on it.
FYI - recently purchased a similar fan for a Ferris from memory, not much change out of $70 AU (had to come from the States)
