Mr Twister
I run through almost a case of Mooshead trying to figure this one out.
Mower does nothing when key is turned on to start. Without checking anything I put on a new start/selinoid. Stupid I know better....no change still dosen't do anything. I checked the following safety switches: both steering handles, hand brake, seat, pto (blade magnet works) both in line fuses & the on/off switch & battery. Everything checks out good.
With brake on, steering handles in correct position sitting on seat I have a closed circuit from the switch post S to motor wire harness plug.
I'd appreciate some tech help.
Terry
Terry
