Scag walk behind with wrong engine?
Richie F
Have a Scag SW36-14KA with a Kawasaki one cylinder OHV engine on it.
There is no label on the engine for information.
In the parts breakdown of the mower this unit should have a flathead engine.
Was there a serial number or year that the mower came with an OHV engine?
Most likely you have FC420V series engine which Scag start listing in the IPL when the 7 digit serial numbers appeared. Doesn't list a spec number. Also is could be recoil or electric start version.
Richie F
Thank you for the info. That engine is 14HP and should be the spec for the 36" cut deck
I not saying it not spec'd that mower. I saying that you would looking various FC420V engine to find the correct parts as there are multiple versions out there under under different spec (type) numbers.
Richie F
I'll have to look to see what bore size I have to be sure, but it gives me direction now.
I see parts for this engine looks to be on Ebay now also.
